- Thu Jul 11, 2013 11:21 am
#334101
Well my car is a full obd2 swap but I know as soon as I tell them an obd1 car is obd2 they won't listen and probably try obd1 testing. Will I fail? How do I pass without converting down?
- Thu Jul 11, 2013 12:24 pm
#334103
What state? What motor swap? Did it fail already?
- Thu Jul 11, 2013 1:18 pm
#334107
I live in Texas. Its a B18B1 swap. My inspection isn't up until September, but I wanna get any issues I might have resolved before then.
- Thu Jul 11, 2013 2:04 pm
#334108
How do they test obd1 vs obd2 in your state? In ohio, obd1 cars are put on the Dyno with a sniffer in the exhaust pipe. Obd2 cars are only diagnostic. So here an obd1 car with obd2 swap would just go on the Dyno/sniffer. Swapping to something newer isn't the problem in most cases. It is when you put an older, less efficient, higher emissions engine into a newer vehicle that causes problems at emissions check.
- Fri Jul 12, 2013 7:26 pm
#334147
It will be treated as an OBD1 car. It's based on the chassis, not the engine.
I'm surprised Texas has emissions testing.
- Fri Jul 12, 2013 10:54 pm
#334151
Thanks for the help guys. Yea in Texas we have emissions tests in the metro areas, Houston, Dfw, Austin, San Antonio. Messed up thing is if I lived 10 miles down the road it'd only be safety
