By LionHearted1 - Sat Oct 29, 2011 5:38 am
#279412
Hello everyone, and thank you for taking the time to listen to my problem.
I was really hoping my first post of this forum would be under better terms, but unfortunately, that's not my situation.
I'll start this off by saying the most frustrating part of this is that just about all of these problems are intermittent.
So, the speedometer in my cluster spazzes out from time to time. It will either work, randomly flip out, or read at 0mph. (This is the most constant of the issues.) I looked into it, and the most reasonable problem is a bad VSS, no real issue, simple 15 minute and $120 fix.
The other issues (and this is where it gets WTF-y) are...
1) My fuel gauge is no longer correctly monitoring the amount of gas in my tank. I put 6 gallons in the other day from empty and it's reading at nearly full.
2) The car is no longer keeping an accurate track of mileage. I drove to work the other day (easily an 11 mile drive) and the odometer clocked a whopping 1.7 miles.
3) When I brake the car, the engine revs. Not a whole lot, but about 500RPMs.
4) The seat belt check light does not come on if I take my seat belt off.
Not really worried about this as I know when I am, or am not wearing my seatbelt, but I figure this would be a symptom of a larger issue.
5) The temperature gauge also isn't as accurate. I know that it's getting colder, so it reading a bit lower seems normal, but I live in sunny South Florida... so... that's just doesn't seem to make sense.
From what I've gathered, the possible problems would be a failing cluster itself, but the car only has 54,000 original miles on it(no lie) so it does seem rather strange that this part would fail so early.
The soldering in the dash cluster has gone bad, apparently this is a common problem for these cars?
or a bad 02 sensor (seems like this is the least likely, but I suppose it could fall in the realm of possibilities?)
The car is my daily destroyer, so not having it running in top condition really isn't an option for me. Any advice or suggestions would be more than welcomed.
Thank you for your time.
