ECU, Wiring, Sensors
By RottenEg6
#212252 So I just picked up some M3 Side Mirrors on eBay. The installation seems easy but the wiring not so much.
I looked at the DIY power mirror already and that definitely helped but I'm curious on how I would hook up the LED lights.
#212273 you'll need to run the LED wires into your cabin and then find the positives of the parking lights and turn signals and then tap into those wires.
Best bet is to get a haynes manual and/or a test light :thumb:
If you're good at following wires, you can get by with just the test light.
By RottenEg6
#212295 Thanks! :D
By asianrob
#212418 dont you need to run a load equalizers of some sort if they are LED's so the fuse dont blow?
http://www.v-leds.com/BlinkerWarning-Fi ... 83296.html
