ECU, Wiring, Sensors
By hooplin
#209048 I get a cel light and go into limp mode when I try to go past 3k only when driving. When not driving I can rev to 7 k. Cel will stay until next start up it goes away. Any ideas??????
By hooplin
#209065 Can't check the code cause when I turn off the car and turn it back on there is no cel it's only when I try driving past 3k it comes on
By Torch_Ind
#209066
hooplin wrote:Can't check the code cause when I turn off the car and turn it back on there is no cel it's only when I try driving past 3k it comes on
You should still get a code
#209145 These "I got a CEL what's wrong with my car?" threads are always good fun. With enough practice we'll all become psychic.
The code is stored in the ECU. Jumper the diagnostic plug and retrieve it.
By hooplin
#209167
teal_dx wrote:check it before you turn the car off
How do i do that do i jump the thing with the car running?
By hooplin
#209181 Ok its a code 10 and 14 the iat and iavc are plug in correctly. I know my iavc is bad cause i have a loopy idle even after cleaning it. Car is in limp mode.
By hooplin
#209513 Ok i read the codes wrong its a code 20 and 4. would this put my car in limp mode?
By hooplin
#209535 yes it goes like this !!!!!!!!! !!!!!!!!!!!! then a pause then ! ! ! !
By JUICE
#209552 got any friends with a EG that would let you try their ECU? see if it flashes the same..
and a 20 and a 4 code would look like...
!....!.... pause !!!!
By hooplin
#209555
JUICE wrote:got any friends with a EG that would let you try their ECU? see if it flashes the same..
Yeah thats what the code looks like. Well i tested the Edl in the fuse box and the ground for it isnt working. Now im gonna have to trace the wires and see why i have no ground right?
