ECU, Wiring, Sensors
By k20fg2
#80453 well as the title states my gauge cluster doesn't work. nothing, no speed RPM, gas and engine temp. not to mention my signals don't work. the hazards work fine tho. help please.
By Dippin_EG
#80544 blown fuse?
By ej2rey
#80550 Cluster burnt out.
Borrow another and try it. See if that fixes the problem.
A blown fuse would just make it have no lighting.
But if none of the gauges work most likely the cluster went out.
By k20fg2
#80553 tried another cluster and still nothing.
By ej2rey
#80555
k20fg2 wrote:tried another cluster and still nothing.
Damn!
Well sounds to me like you have a short.
So you gonna have to check your wiring.
Take apart mayb. See if you notice any burnt wires.
By k20fg2
#80558 wat about my signals?
By ej2rey
#80561
k20fg2 wrote:wat about my signals?
Your cluster needs to work for the signals to work. Its all in one. The cluster its like a bridge. When connected it bridges the gap and makes contact. The sends the signal to the hazard button and from the hazard botton to the signal lights. That's why i dont know if anyone ever noticed this but if you have the hazard botton disconnected the signals won't work.
Did you check all your fuses?
You might want to check your hazard botton too. Might have gone bad aswell.
Also, another rare problem. The back up switch. Its wired to the same fuse. It probably has a short and its shorting everything out. Put it in reverse and have some one check it your back up lights are coming on.
Just a few ideas. Might want to check them all.
By k20fg2
#81252 ok so an update. i ended up changing the entire fuse box under the dash and everything works now. thanks everyone for the help.
By ej2rey
#81254
k20fg2 wrote:ok so an update. i ended up changing the entire fuse box under the dash and everything works now. thanks everyone for the help.
Ha! Never done that 1 b4 but coo. Fuck checking each fuse just change that whole fuse box lol
