- Tue Aug 24, 2010 4:59 am
#210284
ok so i was bored and decided to put some fog lights in my car, so i got them all mounted up and working
and i leave em on for a while and out they go so i figure i had a short but check all connections and wiring and all is good.
so i check the fog fuse[15A] and its popped so replace it and still no luck, so then i notice that i no longer have DRLs so i start checking fuses and sure enough i popped the fuse [10A] so put a new one in and still nothing, also replaced the second DRL fuse[7.5A] for good measure and still no DRL
after a little research i believe the power source [1 of the 5 single prong option outlets above the ATC fuses] i was using on the fuse block was tied into the DRL fuse circuit, all in all i dont much give a shit whether or not i have DRLs as my headlights and everything still works from the switch but i would still like to know what i screwed up, and tomorrow im going to go and get one of those solder on dummy fuses for drawing power for the fogs
however on the plus side i noticed a blown fuse that controlled my A/C which hasnt worked since i bought the car and its now blowing real nice and cold
thanks
thanks
