- Thu Jul 29, 2010 4:28 am
#206640
So im moving my battery to inside the car and wondering if 4g wiring would be ok with no circuit breaker and no fuse. The battery is not going into the trunk its will be in the front in the glove box.
- Thu Jul 29, 2010 12:09 pm
#206658
YOOOO i wouldnt but a battery in the glove box not really good idea cuz the acid could mess up your car if you tip it
- Thu Jul 29, 2010 1:18 pm
#206662
make sure you use a sealed battery so you're not breathing in toxic fumes
and 4 ga should be good, that's what I used.
My 1992 SOHC Turbo Hatch
- Thu Jul 29, 2010 8:16 pm
#206707
Don't mean to thread jack you but when u relocate the bat in the trunk what the hell do u get to hold it and where is the best place to put the negetive cable to ground to???
i pitty the foo who aint got vtec......
EM1 build http://civic-eg.com/viewtopic.php?t=17256
- Fri Jul 30, 2010 12:53 am
#206726
look up a battery relocation kit. it comes with a black plastic box that the battery mounts inside. Or you could weld up your own bracket. the box is good though because it has a hose to get the fumes out of the car.
- Fri Jul 30, 2010 7:57 pm
#206831
Not just toxic but highly explosive. You've heard of hydrogen?
For drag racing you actually want the battery in the front.
