- Thu Apr 08, 2010 2:49 am
#186240
Hi everyone!
Need some help and advice from the beloved civic community.
recently (within a year or so ago lol) I have update some of my interior and security features.
These features were a good alarm and nice set of gauges that will come to a great use later (total 6 of them
). also i have fitted my radio with an internal antenna block, since my antenna hole is shaved.
Well you see my car has been inactive for sometime due to the fact that I have school and work and couple months ago. i tried unlocking my door and my battery appeared to be facked. going to walmart it appeared that a cell was no-bueno and they have replaced it. this happened about 2-3 times so far. I also installed all of the components and triple checked for a nice and clean install.
I know my updates charge power - alarm is constantly working to protect my car and the gauge set has a constant 12V connected to keep the color memory in shape. also my internal antenna draws power for some reason - as described by the manufacturer.
Well i strongly believe that these factors manage to drain my battery horribly.
No my question is:
how would i check the current draw on the battery using a multimeter? i know i must place the meter in parallel with the circuit to get a precise reading. maybe some advice?
If the the current draw is to big for a small stock civic battery, what would you recommend to use? Optima yellow seems like the ultimate tool at this moment.
Im going to recheck my work so what would you recommend to recheck?!
It be nice to have supendedHatch to chime in but any other useful advice would be taken in and enforced with a true appreciation!
Thanks!
No my question is:
Thanks!
