ECU, Wiring, Sensors
#160887 I've been starting my hatch once or twice a week and the PC680 has held a charge fine, but it's getting real cold (and snowy) out.
The pc680 is a dry cell battery and I've been told once you let it die completely, the battery (and your $130) is history.
If I started the car one more time and let it charge the battery for like 10 mins, then took the battery out and took it inside until spring, would it die? :?
By suspendedHatch
#161343 You wont kill it if you let it die out completely. That's a great battery and will stand up to abuse. But you're right that it's a very bad to let a battery fully discharge (except deep cycle).
This is what you need. http://www.summitracing.com/parts/DTN-021-0128/
Besides using it for storage, you should install the cord permanently and hook it up overnight once a month or so.
