H22A
By mooze
#156965 Image
By mooze
#156966 BEFORE
AFTER
#156978 You're the first on here with this setup :thumb:
That was a tight fit, nice job!
can you post some close ups of the H2D adapter plate setup? What kit did you use?
By mooze
#156982 its a bisimoto kit. can get u pix in just a little. still have some pix of it while it was out with the tranny bolted u 2
By mooze
#157367 have some more pix for you guys. it decided to take a shit on me and jump timing so the vc is off for now. so u get to c the "blue magic" cams. should be able to see the bluish tint. wil try to get better pics later.....also head stamp is p13-2 not just the p-13
By mooze
#157369 Image
By Method
#157408 is h2d using a d series tranny?
By mooze
#157409
Method wrote:is h2d using a d series tranny?
yep
By mooze
#157425 mine was like 800+ didnt know anyone other than bisi made one
By itCouldgeTwoRse
#157426 is the kit just that adapter plate or the fly wheel too? And are you useing a d clutch or the h clutch?
By mooze
#157428 plate flywheel and slave cylinder. using a stage 3 d series clutch
