- Thu Apr 09, 2009 3:01 am
#109302
Well I did this awhile back but finally found the pictures of it.....So here we go......
The tools + parts
-Dremel tool with the cutting utencil or some other way to cut the plastic...and sanding drums or files
-1992-1995 civic Ex door panel pockets (from a 2dr in this case)
-phillips and flat head screw drivers
Step one locate the indent behind the door panel in the plastic that shows you where to cut in order to allow you to use the door pocket.
Step two cut inside that line be careful to only cut through the plastic it is possible but even if you cut through the fabric you would cut that anyhow as well.....just to make sure the fabric dosent lift off too much is what my whole concern was
Step three do a second cut if you feel brave enough if not just go about sanding with the drums/fileing and once you feel like its gotten to the point you need it to be.....
At this time you should only have the main piece fitted through like so
With it fitted correctly all you need to do now is screw it in using regular civic c/c or other screws so once you do that all you need to do is clip on the back and screw that peice in......then reinstall on the door its pretty simple to do just takes some patience...
but in the end it will look like this if done correctly
Enjoy!
The tools + parts
Enjoy!
1980 volvo 242
2001 crv
2001 crv
