K20 & K24
#510 * K series motor/tranny/ECU
* K series engine harness
* K series charging harness
* conversion harness
* B/D series coolant temp sensor and fan switch
* fuel rail
* Universal Fuel Pressure regulator
* Custom Fit Fuel lines
* OEM RSX shifter Box or Modified Accord shifter box
* RSX Shifter Cables
* Shifter linkage Clips
* Aftermarket intake
* Aftermarket Header
* Custom Mid Pipe
* Throttle cable for your application
* EP3 pulley and belt (if retaining AC and OEM belt)
#519 puttin a k20 in the hatch?
#521 nah, K-series is nice but too expensive for me... One day I'd like to go the N/A K route after my SOHC is retired.
By littledelsol
#528 After I finish my engine I plan on buying another del sol and swapping in a K. So this should come in use in a couple months.
By marcokeg20
#9721
* fuel rail
* Custom Mid Pipe
and:
wide band lambda sensor
engine mounts
axle's
and if you've a.b.s in a eg: take it out, because the engine will fit better then :wink:
i've used the original cable's from the ep3 . and i drilled a hole in my fire wall. then ive mounted a del sol dash in my eg with a shiftplate from the ep3'. so my shifter wasn't on the floor anymore 8)
By marcokeg20
#9887 fuel rail
k-pro hondata
shiftnob
invidia g200
ep3 radiateur
special axle's
mount's.
r crew sub harness
k20a2 engine ( duh )
r crew header:
and i ve used the original trammy cabels of the ep3
and fitted a aem fuel pressure regulator
fuel line
By stefan
#9888 Porn on wheels Marco :thumb:
By marcokeg20
#9890 porn on my pc :P
#9900 :lol: :lol: It totaly is sexy to see especially when drunk! :lol: :lol:
By vtec_gloucester
#19138 im really temped to do a K swap next... think i'll wait til parts are abit cheaper and easier to get in the Uk first though! :)
By split sec eg
#33815 i been working at a wrecking yard for 2 years jess waiting till a k come by ... till then im happy with my b20 vtec :D
By hontec
#33943
split sec eg wrote:i been working at a wrecking yard for 2 years jess waiting till a k come by ... till then im happy with my b20 vtec :D
you sure the wrecking yard is not out of business? :D
we have em flushing by once every month... :D
By Ej2-B16a
#35133 personally , i don't VTEC lol
By Benj
#36696
Ej2-B16a wrote:personally , i don't VTEC lol
i know this is a old post but why THE HELL NOT VTEC = :o :thumb: :woot: :hehe:
and what year is a k20a outta???
