- Sat Jul 11, 2009 6:34 am
#129798
okay be kind to me its my first time putting up DIY so i hope i did okay so here i got
first you take out the 3rd brake light
then use a screw driver to take out the screws on the bottom
then pry it open with a flat head screw driver
then it will be in two pieces lift the top up gently and slid out the reflector
now since its all apart you can find a font or what ever you want to say i wanted civic
so i got a pic of a civic that had one
i put the picture on paint and made it the size of the lenses
then trace it out
then i went to the swap meet and had a sticker made for it cost me $5 dollars
then put the sticker on it with a little bit of soapy water and take the bubbles off
and put it together
now im finish this is what you should have
then trace it out
and put it together
