By hatchin06
#71475 ok my driver side windshield wiper crapped out on me. i can completely lift up my wiper and move it freely as you shouldn't be able too. So is it the motor that is broken or is there a piece that connects to the wiper to make it move that snapped. what do i do to fix? thanks
By asianrob
#71483 just replace the motor assembly. but it could be also that the teeth on the wiper arm and motor are stripped.
By hatchin06
#71485 So is the motor assembly and the teeth on the wiper arm 2 different things? is there a way i can check to see which one it is if it is 2 different things?
By civic_man09
#71498 take off the wiper arm...look where it came off of and see if there are still splines on it...if the splines are worn off then thats your problem...
By asianrob
#71500
civic_man09 wrote:take off the wiper arm...look where it came off of and see if there are still splines on it...if the splines are worn off then thats your problem...
X2
