- Tue Jun 03, 2008 1:15 am
#57371
Why upgrade the fuel rail?
It's able to flow enough fuel to feed up to 450hp...
And the only reason you should get another fuel pump is because you need the reliability of a fresh one, go with in tank or external, what you want (
link to a nice article/how-to by Endyn)
The stock one you have now has enough capacity for at least 325hp and more, but is not as reliable as a new one anymore.
So get a new one, unless the thing was replaced in the last 4 or 5 years.
Just add a decent fuel pressure regulator, get 440cc tot 550cc injectors, and have the car tuned by a guy who really knows what he's doing.
And get a 70mm throttle body, a header specifically designed to work with a supercharger, a large diameter decat and catback... that'll give you the power you want (probably more haha).
The heatshield gasket (Hondata or Password:JDM, doesn't matter) is a nice thing to add as well, it's cheap, so do it
Good luck, I'd like to see those numbers you're going to run
