- Sat Mar 24, 2012 4:37 pm
#299638
I am doing a motor swap in my 95 cx. When I tried to remove the torque mounts from the frame the nut that's welded to the actual frame broke loose and now the bolt just spins. I thought of just welding the mounts to the frame. But, they need to be replaced badly. I have some spare Aero aluminum and was wondering is there anything I need to take into consideration before I cnc my own mounts?
Like the durometer of the insert?
I noticed it only uses 2 bolts but there are another 2 holes. Will 2 be good or can/should I use 4?
