- Fri Feb 24, 2012 3:37 am
#296053
ok guys maybe you'll be able to help me out, i started working on it this morning and just ended, i found out that the guy before me had tried this before and the bolts holding the fenders on each side were rusted beyond belief so after i got that off i started cutting out the vents and mounted the lights everything was good, i hooked up the power wire to the battery, mounted my relay to the side of my engine bay, i did all the wiring correct, i put the yellow wire in the #2 spot in my fuse box everything works except they wont turn off EVEN when my car isnt on they wont turn off, does anyone have a idea...thx
i forgot to take a picture of it all put back together but i will after i get this little problem sorted
What you know about being a hella noob?
