- Thu Oct 06, 2011 3:44 am
#276465
RWMIII wrote:user1 wrote:EG6b20R wrote:http://civic-eg.com/viewtopic.php?t=7800
Thank you...that was the write up that states the 90-93 integra axles will work....But another post on this site says i have mix and match the driver side due to the required female connector or somethin....I'm just looking for confirmation that, as is, the integravaxle will work with no issues, leaks, etc.
The article specifies:
90-93 Integra axles + the inner CV snout of a 94+ Prelude or Accord
Accord(94ish) Driver's side mid shaft
So from the article and personal experience this is what you will need. And if you build it correctly (and use parts as posted) then it will not leak, bind, or pop out of the tranny.(the issues that I assume you are thinking of).
Further down states,
Almost done! Just need some axles. As mentioned, I used a 94 Accord driver's side mid-shift.
Driver's side axle from a 90-93 Integra(trim package doesn't matter, make sure if you have ABS you get the axle with the ABS ring on it). You will have to make a custom passenger side axle. Cut the CV band off the Integra passenger side axle and remove the snout that goes in to the trans. Take your Prelude/Accord CV snout and put it on the Integra axle with some extra grease.
Is this incorrect...and I in fact need to create a driverside? Once again...appreciate the help!!!!!
