Spring rate questions
Postby Ajax1989 » Wed Feb 16, 2011 9:00 pm
What would be a good spring weight for my 4dr?
I want a nice smooth ride, but have to handle good when I hit
up canyons or the track
I have stock sway bar in the front
and a stock DA sway bar in the rear
but when I can afford it im updgrading to
Eibach sway bars 27mm front and 17mm rear
if that helps any
Oh and im looking at FF type 2's
Thanks Aj
Ajax1989
Nissan Primera
Nissan Primera
Postby AutoXCivic » Wed Feb 16, 2011 9:04 pm
I will probably be putting 10k/8k coilovers on my AutoX/DD car this year. I have been running Tein basics for a while which are 7k/3k (IIRC). They handle pretty well and aren't too rough. I suggest finding some people with stiffer spring rates and getting a ride along to see what might be too harsh for you.
Straight lines are for sissies.
AutoXCivic
EG Groupie
EG Groupie
Postby Ajax1989 » Wed Feb 16, 2011 9:11 pm
well my ride as of now is blown stock shocks in the front with ebay coils
and blown tokio blues in the rear on ebay coils
but when u say 10k/8k what do you mean
i know a lil bout suspension but theres is some i dont know
Ajax1989
Nissan Primera
Nissan Primera
Postby AutoXCivic » Wed Feb 16, 2011 11:17 pm
10k and 8k refer to the spring rates , they are usually arranged in a Front/Rear manner. The 10k is 10kg/mm which means it takes 10kg of force to compress the spring 1 mm. A 10k spring rate is equivalent to about a 560lb spring rate (which takes 560 lbs to compress the spring 1 in). So 10k/8k is about the same as 560lbs/480lbs if you understand spring rates better in standard measures.
If you are riding on blown shocks ... just about anything is going to feel worlds better to you.
AutoXCivic
EG Groupie
EG Groupie
Postby Ajax1989 » Wed Feb 16, 2011 11:36 pm
so 10k/8k would be the best?
do you know if the FF Type2's have that spring rate or can i get them with that srping rate?
Ajax1989
Nissan Primera
Nissan Primera
Postby AutoXCivic » Thu Feb 17, 2011 12:50 am
Best is reaaaally subjective. I depends on what you are going to use it for. If mine wasn't also a DD I'd probably opt for stiffer spring rates. It all depends on usage, the types of roads you have, and how rough of a ride you can tolerate.
I'm not sure what the spring rates on the F&F Type 2s are. Perhaps someone else can chime in on that?
AutoXCivic
EG Groupie
EG Groupie
Postby Ajax1989 » Thu Feb 17, 2011 12:57 am
i live in southern california
and our freeways are fucked
i want more of a smooth ride rite now
the car will barely see any track, or canyons, only once a blue moon will
i take it to the canyons
Ajax1989
Nissan Primera
Nissan Primera
Postby AutoXCivic » Thu Feb 17, 2011 1:00 am
In that case I might opt for something a little lighter than the 10k/8k although lots of people have that and like it just fine.
Honestly you'll probably be fine with the F&F Type 2s, I've heard decent things about them.
AutoXCivic
EG Groupie
EG Groupie
Postby Ajax1989 » Thu Feb 17, 2011 1:34 am
according to this
http://www.f2autolife.com/sites/default ... 282%29.pdf
the type2's are
12k/8k
and the type 1's are
10k/6k
so would the type 2's still have a smooth ride?
Ajax1989
Nissan Primera
Nissan Primera
Postby Fada Blayne » Thu Feb 24, 2011 8:55 pm
Yea that setup should be just fine. The front is going to be nice and firm. I'm planning on doing 12k's all around on my coupe. :thumb:
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Fada Blayne
EG Groupie
EG Groupie
Postby Greasedmonkey » Fri Feb 25, 2011 1:54 am
For spring rates there is really no BEST choice. Its all up to you. 10k.8k is too soft for me. I have 12k/9k and will be upping that to 12/10 when I can. To me these are perfect.
With those Eibach sway bars you will have tons and more understeer. You dont really need a bigger sway bar in the front. Stock works just fine. Just get a bigger rear bar.
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
Greasedmonkey
Hm which Teal Hatch shall I drive today?
Postby Ajax1989 » Fri Feb 25, 2011 2:13 am
im just lookin for a nice smooth ride, but handles good, our freeways and roads are beat up out here
imm just gonna go with the type 2's
and just the rear eibach sway bar will be enough?
Ajax1989
Nissan Primera
Nissan Primera
Postby Greasedmonkey » Fri Feb 25, 2011 8:07 am
Dont worry about Eibach. Nab a ITR bar.
I know how Riverside is, I lived there. My 12/9 set up is smooth.
1986 Nissan 300zx
1980 Kawasaki KZ650
Greasedmonkey
Return to EG Chassis Suspension
Who is online
Users browsing this forum: No registered users and 0 guests
