- Mon Oct 18, 2010 7:31 pm
#218851
RPGonzos_EJ wrote:asianrob wrote:its deff looks OBD0 by the manifold. looks like a B18A1 from 90-91 integra.
get an 94-95 intake manifold or buy an aftermarket one. and throttle body while your at it. unless you want to run a stock throttle body from 94-95 integra. you can get away with using your engine harness,
should be able to get away with using that PR4 ( i think thats 92-93 integra ECU)
need to convert the timing side Motor mount to the 3 bolt bracket with the aluminum mount.
need OBD1 LS dizzy (92-95 integra LS will work)
theres probably a few other things. im pretty sure some one will mention it.
Along with the dizzy your going to shift linkage & O2 sensor if you don't already have it. The factory O2 of the OBD0 LS motors is a one wire, you need the 4 wire from the OBD1 92-95 Integra.
The PR4 ECU is from the 90-93 Tegs and is OBD0 so your going to need to find the right ECU like a P74 or P75 (just examples you choose what you prefer of course.)
+1 on changing the IM and TB, i used the IM and TB from a B18B1 because it had less vacuum ports and was a lot simpler looking.
http://cgi.ebay.com/ebaymotors/1994-199 ... leQ5fParts
Disclaimer: I am not promoting the seller of that item i just happen to find it!
If the motor came from a auto teg and you want the 5 speed of course you will need to replace the flex plate with a flywheel and clutch.
90-91 are OBD0 and 92-93 are OBD1 just clarifying that.
theres minor diffrences in the ECU
the PR4 is believed to come in OBD0 and OBD1 config.
OBD2B (left 3 plugs used)
OBD2A ECU
OBD1 ECU < plugs should look like this.
OBD0 (JDM PR3 and PWO)(bottom to top)
shift linkage should be from 94-01 integra, (99-00 Si will also work)
and 94-01 integra "L" bracket
trans
and clutch/pressure plate as mentioned.
throttle cable ($15 @ Acura for Type R/LS)
i would do a tune up on that motor and replace the blets and gaskets. before throwing it in.
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
