- Fri Jul 09, 2010 7:19 am
#203815
so i am going to be replacing my clutch very soon and i was wondering if i should get a stage1 or oem replacement?? i have a D16z6 with intake and header.. ima use it for daily drivng but i wanna have something fun to drive too..
- Fri Jul 09, 2010 3:19 pm
#203842
OEM replacement. Exedy is a good bang for the buck. Don't get that Autozone crap.
- Sun Jul 11, 2010 2:49 pm
#204113
i would stick with OEM cause a stage 1 will slow you down if your not pushing a decent amount of power. i heard that the zoom clutches are pritty good... i have a edelbrock mani, header, full exhaust and an EX tranny with and OEM clutch and it works great and its real good from a hole shot too
- Sun Jul 11, 2010 4:05 pm
#204121
can you please explain how a better clutch can make you slower
- Sun Jul 11, 2010 5:25 pm
#204130
i still dont get it. if a stage 1 clutch slows you down. then an oem clutch would make you faster yes? please explain how a clutch that can hold less power makes you faster. (if both have the same moment of inertia)
correct me if im wrong but..
im pretty sure that the main differences between clutches is how hard they bite/engage, how much power they can hold before they slip, and how long they will last.
a 4 puck stage 5 clutch can hold X amount of power but isn't intended for street use because it engages so hard and chatters.
where i am running a clutchmasters fx300, 110% increase in holding capacity and it has in no way made my car slower and is completely streetable. clutches dont make power they transfer it to the trans...
- Sun Jul 11, 2010 5:46 pm
#204133
Exactly.
I had a crapy XTD stage4 6-puck unsprung on a mini-me set up for months before i turbo'd it. The clutch isn't going to slow you down.
Upgrade since you'll already be there. You'll kick your self 1 for having to take the trans back out, and 2 for having to buy a SECOND clutch, when you could have just bought one in the first place.
VerLee24 wrote:i still dont get it. if a stage 1 clutch slows you down. then an oem clutch would make you faster yes? please explain how a clutch that can hold less power makes you faster. (if both have the same moment of inertia)
Exactly.
D16z6. Golden Eagle. AFI Turbo. Precision Turbo. Hondata. CG racing.
618hp, 407tq SOHC 10.68@137
My 92 hatch SOHC build. Quest for +600hp. Check it!
- Mon Jul 12, 2010 8:00 pm
#204301
Yes go with stage one !!! Me and you are doing the same build and I'm still on my oem clutch it's starting to squeak so I'm going to replace it soon with a stage one act clutch and fidanza flywheel
I'm going to the gulf, swim down and plug that oil leak with my dick
- Tue Jul 13, 2010 6:13 am
#204376
same here but i cant afford ACT lol gotta stick with Excedy
EJ1-danny wrote:Yes go with stage one !!! Me and you are doing the same build and I'm still on my oem clutch it's starting to squeak so I'm going to replace it soon with a stage one act clutch and fidanza flywheel
