Dimmer switch fix?
ECU, Wiring, Sensors
Dimmer switch fix?
Postby Tristanw10 » Wed Jun 09, 2010 8:24 am
I thought i ran across a thread on how to fix the intermitten dash lights caused by a dimmer switch, can someone please direct me to that thread or tell me how to fix it, thanks.
Tristanw10
Poster
Postby n0safebetdx » Wed Jun 09, 2010 8:41 pm
It's actually really simple it just pops out and you pop the new one in....if you havent found a new one yet good luck finding on that works...
I had to replace mine and my new one stays on all the time I can't dim anything my old one only worked when it wanted to!
(psssst... Did you know I'm not a dude?)
n0safebetdx
EG Regular
Postby kinta94 » Wed Jun 09, 2010 10:22 pm
i have 3 dimmer switches for sale if you would be interested in one they all work perfectly.
kinta94
EG Regular
Postby Tristanw10 » Thu Jun 10, 2010 8:21 am
so there is no way to fix the old one?, i would be interested in buying one from you though, how much you asking for them>?
Tristanw10
Poster
Postby suspendedHatch » Thu Jun 10, 2010 5:48 pm
Pull out the plug and put a jumper between the red and black wires. NOT the red/blk!
suspendedHatch
Knows Hondas
Knows Hondas
Postby Tristanw10 » Mon Jun 14, 2010 4:01 pm
Thanks do you have a D.I.Y, on this?, just not certain how to do it
Tristanw10
Poster
Postby suspendedHatch » Mon Jun 14, 2010 4:18 pm
Quit kidding around man.
Stick this in the harness to jump the red to the black wire. Or you can just cut these two wires and connect them.
People need a write-up to zip their fly these days!
suspendedHatch
Knows Hondas
Knows Hondas
Postby Tristanw10 » Mon Jun 14, 2010 5:09 pm
I just wasnt clear on what method to use when jumping the wires lol, thanks for clarifying it for me though..
Tristanw10
Poster
Postby suspendedHatch » Tue Jun 15, 2010 3:59 pm
You're welcome. :lol:
suspendedHatch
Knows Hondas
Knows Hondas
Postby JohnAWESOME » Sun Nov 06, 2011 10:00 pm
Hey I am having the same thing with my hatch. I did a led conversion on my cluster and one of the bulbs ended up shorting out and melting down since then I have had no parking lights or dash lights. I checked the 10a fuse and changed it out and also put back in a bulb. I did a jumper on the dimmer switch red wire to black wire with a 20 gauge wire still no lights. Is there any way to directly wire up my lights??? Or is there anything else I might be missing?
JohnAWESOME
EG Regular
Postby JohnAWESOME » Tue Nov 08, 2011 5:28 pm
Bump
I think I will just take it to a shop to get looked at I suck at electronics
JohnAWESOME
EG Regular
Postby 93sihatchguy » Thu May 01, 2014 9:18 pm
Sorry to bump an old thread, but I finally got around to doing this. I used a #10 Spade terminal to jump the red and black wires together. Just be sure not to use the red/black wire.....
93sihatchguy
EG Regular
Return to Chassis - Electrical
Who is online
Users browsing this forum: No registered users and 0 guests
