CaliEJ2 wrote:well today was my last day driving my b16a :( .... im going to pull it out mañana and drop in a d16z6
gotta hate cali :x
By CaliEJ2
#188530
gotta hate cali :x
most definitely :thumbdown:...
but the next swap that i get im gna get one that wont be a problem... either a b18c1 or c5.. or build a poormans type r... idk. but i want turbo though. 8)
By redciv1
#188563 Very nice tranformation. One question though. For the rear disc conversion what all parts did you grab from the DA teg and was it a straight bolt on for the EJ?
By CaliEJ2
#188597
redciv1 wrote:Very nice tranformation. One question though. For the rear disc conversion what all parts did you grab from the DA teg and was it a straight bolt on for the EJ?
pretty much just the whole trailing arm setup. It was all bolt up but the tabs for the e-brake cables dont line up perfectly so u gotta make them fit. Pretty easy though.
By redciv1
#188606 Thanks for the reply. Nice to see replies :thumb: .
CaliEJ2 wrote:
gotta hate cali :x
u swapin it cause its a jdm motor??
jdm motor + cali= big no no..
i think its stuipd they banned jdm motors out here..
nd its all cause of smog.. and a jdm motor doesnt put out anymore smog then a usdm motor :x
By CaliEJ2
#188663 yup its so gay..it looked so nice in my engine bay :cry: :cry:
By CaliEJ2
#188701
dro21 wrote:what the? i thought ca made it so you can swap jdm motors in as of january?
link w/ info:
http://www.honda-tech.com/showthread.php?t=2739404
ive heard yes and ive heard no....i read that you have to make the motor identical to the usdm one. Even if it was legal i probably wouldnt have done it. I wouldve had to find and buy a P30, not exactly cheap and easy to find, i would need a cat( i dont have one), stock intake and manifold, headers, and hope that it passes after all that. I dont have a fat wallet at the moment so yea lol. Besides, i was having some problems with it.
Im trading it for a complete z6 swap with a cat and stock piping. The guy had just taken it on Friday to get his car smogged and it passed. Plus im getting cash on top and saving all that money if i were to even try to smog the b16.
Extra money= car parts 8) :woot: :thumb:
link w/ info:
i thought you couldnt, and smog techs told me no
but this changes it all
Replacement Engines
Entire engines can be replacement parts. As with any other replacement part, the engine must be identical to the original. If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block.
If the engine is not identical to the original then it is not a replacement part, instead it is considered an engine change.
Engine changes are a modification that must meet certain requirements to be legal (please see "Engine Changes").
Japanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle.
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
Vehicles converted to 100% electric drive, with all power supplied by on-board batteries are considered in compliance with the engine change requirements. All fuel system components must be removed prior to inspection. For additional information contact the ARB helpline at (800) 242-4450
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
humm idk, jsut go down to the local ref and talk to them.. last time i herd as of april 1 2009 no more jdm motors
By CaliEJ2
#200697 ok new updates... since the last time i posted i have swapped in the z6. polished the lip on my rims, painted my valve cover, polished the side mount a bit, and cleaned up the heat shield. and thats pretty much it lol.
Before
bought a spare VC
after
Polished lip
should i lower it more?
By Classiccarsrule85
#200700 looking spiffy....
and on the lowering part unless your scraping its not low enough unless you live where i live and the roads are shit lol.....but to be honest that looks like a good height.....
#200705 man you coupe is beautful makes me want to sell my sedan and get one :thumb:
By dro21
#200708 i see ur front bumper doesnt line up with the headlights....mine doesnt also :?
By CaliEJ2
#200709
94_jdm_ferio wrote:man you coupe is beautful makes me want to sell my sedan and get one :thumb:
thanx bro.... youuuu wont. lol
nope, i hate it. theres more of a gap on the driver side. idk what to do to fix it.
