B16, B18, B20
By RAKUN
#51302 hi
i put the gsr b18c1 in my hatch 95 si with all the normal stuff
the problem is this,
i put the ecu from the integra to my si and it plug in without ecu-jumper but my check engine lights on just after i start to drive
how i can make it to work like normal?
im planing to take my si to the B.A.R. the get my stamp
any sugestions???
thanks
By LowTEC-Derbo
#51328 only wires that needed to be added were at D3 for the knock sensor and A17 for IAB. The pinout for the IAB can be switched from A20.
if you have VTEC.
you also have to make sure all your smog emission stuff is plugged in as that is the biggest thing they want to be sure is valid on the engine.
By RAKUN
#51378 yes i have vtec
but exactly what and i have to add?
do you have some pics?
thanks
