- Mon Mar 13, 2017 2:39 am
#361350
i need help lol...
i had the car wiretucked from my old mechanic a few years ago, i never started it cause it was never finished but the wire tuck was really legit...he made a new engine harness using new wires and wires from my original harness.
I noticed that after i got the car mostly done, and only thing left was the wiring, i found a few wires that are not connected, 2 brown, and 1 black, and also 1 thick black wire that seems to be for a ground, and also a white wire with a O connector as the end which i assume is for the fuse box. also found a red/yellow wire that seems to be cut, and a brown/black wire cut from ECU harness...
i try to connect the browns and black wire to the G101 ground in thermostat directly, but that didnt work. no fuel, no crank...
i basically need a very thorough guide to all the wire colors and pinouts for the shock tower plugs, ecu obd1, and engine harness..
here are pics to help if needed
i dont know where these plugs connect to...vvv
i dont know where this thick black wire goes to...might be starter, or alternator...
my attempt at trying to make a G101 ground work...
let me know what should be my next thing to try and do...my brain is fried since i been working on this car in a hot garage for a few hours lol
Midori Green EJ2 Build
http://civic-eg.com/forum/viewtopic.php?f=60&t=30455
