- Wed Feb 06, 2013 10:45 pm
#325741
I dig higher cr turbo builds.
Just make sure tell your tuner before you tune.
Fada Blayne wrote:8.5 is going to have some serious turbo lag
You'll be fine going with a ratio such as 10:1,etc and before the critics say otherwise I've personally seen ratios as high as 10.5:1 boosted (reliably) to great success.
If you are still a bit skeptical 9.5:1 would be ideal but in todays day and age ur original choice won't be sufficient in terms of hanging with the comp.
Wishing you the best of luck with ur build, research,research,research and you'll be ok.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
