- Thu Jun 09, 2011 5:30 am
#258733
Hi guys,
I recently took the throttle body off and iacv an gave them a clean with a throttle body cleaner, i put it all back together.
But i accidentally knocked the throttle position sensor so the idle was bouncing up an down, I calibrated the tps back to standard 4.5v WOT 'wide open throttle' and .48v CT 'Closed throttle'
And now i start the car up it will idle fine, but as soon as i touch the throttle it will rev to 3k at idle or when the clutch is engaged,
the car drives normal when in gear an i just replaced the alternator belt today not sure if that changes anything.
Link To Video of what the car is doing - http://www.youtube.com/watch?v=eGLF08shzJQ&feature=player_embedded
btw the car is a eg5 with a jdm b16a
Any help would be much appreciated
Cheers
Cheers
