- Wed Apr 20, 2011 3:01 pm
#251343
ok how fast could you spin a stock b16a1 crank with Carrillo Pro-A Beam Rods and type r pistons? i'd like to spin as high as i can with up it going boom.
- Wed Apr 20, 2011 4:37 pm
#251352
Do you mean speed of the engine (RPM)? or do you mean road speed (MPH) as these are 2 different things and many factors come into play for both.
RPM would require full engine rebuild and internals swaps for pretty much everything to compliment you rods and pistons plus it would then be down to the tuner to finish the job right for you.
MPH some the same as you'll need to rebuild and swap most internals and VC plus look into what gearbox you'll be running and final drive options for all out top end speed, this then may send you down the boost route if you want it quick, or all motor which can cost more to achieve.
Then would come wheel and tire options and sizes, aero, weight, fuelling, handling and most importantly safety for the driver.
