- Tue Mar 29, 2011 12:59 am
#246829
i have a b16a2 swap in my eg and it was running fine until today. i started it up this morning and added fuel injection cleaner to the gas tank like its stated on the bottle. ( i was going to dmv to get my tags) well the car ran fine and dandy to the dmv. when i got there i put in a fuse for the speed odometer because it had blown. ( idk why it fuse keeps blowing might be because im missing driver side front turn signal?) when i waited in line i turned off my
car. and when they told me to pull forward the car started up as usual. they told me to turn off the car so they could check my gas cap. when they finished they told me to pull forward i turned on the car; again the car started fine. when they guy tried to start the car it would start then about 3 secs it would stall. and he would try and start it again and it would just crank without any luck. so they pushed my car out and that stupid son of a biscuit bent up my front bumper. when the car was on the side of the building i noticed that it would prime then the car would start then die. if you tried to start it right after it wouldnt prime( you would have to wait a little bit for it to prime again.) when it did prime i started it and it would die once again i looked at my fuel pressure and it was low again.
whats strange is sometimes the car would start but sometimes the car starts but stalls. this is my only daily driver. i hope you guys can give me some insight.
