- Fri Feb 18, 2011 7:57 pm
#239572
Ok sorry of the dum question but I'm taking my b18 motor out of my eg this weekend can any one direct me in the right direction on where to start I have all the tools and equipment but don't know where to start I wanna pull the tranny and motor together is this possible
if you want to drop it from under the car make sure you have enough room. if from under the hood you nee a cherry picker or engine lift.
first. disconnect the battery
drain all of the fluids and disconnect all of the coolant lines, harness, and fuel lines
second. remove the exhaust, shift linkages, tie rods, shocks, lower control arms, and axles
third. support the motor and trans, then unbolt the mounts. remove the motor and trans all in one.
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
91 s10 (sold)
