B16, B18, B20
By civic_84
#214997 hey all, need some help pls. im in the process of putting a a b16 into wot was my 1.5 lsi, with regards to the wiring loom wot sthe easiest way for make it fit, i have taken the litterallly the whole loom out of the crx i took my b16 from but obviously dont want to rip the whole loom out my civic the b16 is goin in...any help would be great as i want to get it up and running by early next week.. cheers guys :)
#215002 What year car is the motor from?
By Classiccarsrule85
#215007
Greasedmonkey wrote:What year car is the motor from?
x2
If its what im thinking then I would also like to know what year your civic is if the 1.5l lsi is obd0 then you should have dpfi and with that you will need to wire up the mpfi.....youll probaly want to use your stock wire harness if its obd1 and just lengthen some things
if you grabbed the entire harness and stuff from a crx then youll have to find a hydro trans for the b series engine but not 100% on that....
but yea it all depends on what year civic you have what obd it is and what obd the crx was.....
By civic_84
#215089 the crx was a 1990 yr and my civic is a 1995 1.5 lsi
