B16, B18, B20
By KittyrdzEG9
#210786 Okk, i need a lil help here; i have a budget of $2000 to do a swap;
my question, what swap would b good for my 4dr?.
Do i need more than this:
(- Motor
- Tranny
- ECU
- Axles
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- All Sensors Needed ) to do a swap?? if so what else??
By poorman type-r
#210792 Are you planning on just having a stock b series to feel a little more power than a single cam or are you looking to build it too? Because with 2 grand you might be able to get a gsr swap but i would go with a b16. It really just depends what you want to do with the motor.
By KittyrdzEG9
#210920
poorman type-r wrote:Are you planning on just having a stock b series to feel a little more power than a single cam or are you looking to build it too? Because with 2 grand you might be able to get a gsr swap but i would go with a b16. It really just depends what you want to do with the motor.
Wow now it hit me; idk, bc i really want the car to go more faster thats all, and probably beat on it a lil bit, but it wont b for be racing it everyweek; is gonna b my DD
By poorman type-r
#211002 If you had 2 grand i would say go with a b16. Its more power than a single cam and it is really cheap, especially compared to a gsr. An b18b is a good motor but you don't have vtec and the ls-vtec is the most unreliable motor. So yeah, a b16 is a way to go. Are you going to try and get it barred or are you just going to swap it in and swap your single cam back for a the smog.
By KittyrdzEG9
#211007
poorman type-r wrote:If you had 2 grand i would say go with a b16. Its more power than a single cam and it is really cheap, especially compared to a gsr. An b18b is a good motor but you don't have vtec and the ls-vtec is the most unreliable motor. So yeah, a b16 is a way to go. Are you going to try and get it barred or are you just going to swap it in and swap your single cam back for a the smog.
what u mean swap back the single cam for a smog?
By HondaHoe187
#211009 yea id go with an sir2 or a gsr swap!!!!!b series FTW!!!!
By poorman type-r
#211013 Your b series wont pass the emission test for a smog.
#211041 Why wont it pass? Loads of people have B series motors that pass all sorts of smog tests.
By poorman type-r
#211044 Here in cali. you need to have your engine barred to get it smogged.
By KittyrdzEG9
#211100 Oohh i got u; mmm if it wont pass ill do that... Soo i guess thats my final decision B16 SiR II 92-95 ( http://hmotorsonline.com/shop/sc2000sea ... item=30005 )
U think iam gonna need something extra?? Bcsz is a compleate Change Over, but i need to know if i would need something extra that i wouldnt know, bc my friend is gonna do it and he can say that i need something else and use it for another car without me knowing.
By 1995db7
#211109
KittyrdzEG9 wrote:Oohh i got u; mmm if it wont pass ill do that... Soo i guess thats my final decision B16 SiR II 92-95 ( http://hmotorsonline.com/shop/sc2000sea ... item=30005 )
if its a complete changeover you wouldn't need anything else and that so call "friend" doesn't sound like one if he would tell you that you need more stuff just to turn around and sell it
By poorman type-r
#211111 Go to this- http://www.jdmtigerjapanese.com/autopar ... &query=257
I think there motors are cheaper, but the only thing i think you will need is axels and mounts, but you live in Florida and you can swap any motor in without going through all the regualtions like we have here in Cali. so you should be good on that
By poorman type-r
#211112 When you click on that link i accidently gave you the one that gives you just engine only, so scroll up and click engine and transmission on Honda/Acura.
By KittyrdzEG9
#211377 Nice thanks guys; hopefully i keep updating to let u guys know how iam doing with the swap; and yes Iam doing B16
By KittyrdzEG9
#211378
poorman type-r wrote:Go to this- http://www.jdmtigerjapanese.com/autopar ... &query=257
If u do the math is almost the same iam spending; it is cheaper but i think is the same
