B16, B18, B20
By illason
#190271 Hey I have a question...I just swapped out my motor for a gsr and I noticed the axle was leaking a few drops of transmission fluid. what can cause this? what can i do to fix it? Please help thanks!
By That One Dude
#190274 Pop the axle out of the transmission and replace the seal.
I'm guessing you know how to do that since you just finished the swap.
If not, I or someone else will be able to guide you through the process.
By Apexracing
#190313 make sure that its fully seated, it should be flush with the housing when seated correctly
By forcefedEG
#190367
Apexracing wrote:make sure that its fully seated, it should be flush with the housing when seated correctly
x2 if not it then ->
That One Dude wrote:Pop the axle out of the transmission and replace the seal.
couldnt have said it better myself :thumb:
By illason
#191882 thanks!
