B16, B18, B20
By 99cx
#187770 Okay just swapped in a B18 in my CX
go to start it and it clicks, so i thought my battery was toast.
got the jumper cables and tried again.
now only my dash lights and e brake lights and stuff comes on
no engine, oil or battery lights flash when turned to the on position?
but i did it the first time before?
i guess a have a wiring issue... but where and how?
anyone have any ideas? i turn the key over and i get my main relay clicking and i hear one from the under dash fuse panel too.
What a bummer on first start up! :x
By flyinryan122
#187787 Make a ground strap from the tranny to the chassis, then on the drivers side make one from the chassis to the head/valve cover.
Sounds dumb, but i've seen this happen a bunch, one ground from the chassis to the trans and the cars all fired right up.
By 99cx
#187788 wow you know what! i totally forgot to put that back on!
i got the one on the valve cover but im going out now to do the tranny!
By 99cx
#187793 WELL wouldnt ya know it!
it turned over!!!
HAHAH WOW didnt think a ground would make a difference on the tranny!
You sir, are amazing :thumb: :thumb:
unfortunately it didnt start
checked the codes and it saying 3 and 11?
By flyinryan122
#187798 You are welcome :woot2: hahaha
3 is MAP sensor. 11 isn't on any list i have seen?
By 99cx
#187799 well only have a exhaust manifold and downpipe on it right now
would that cause Code 3 and 5 Manifold Absolute Pressure
and also i have a P75 installed.
would that be the Code 0 and 11 Electronic Control Module (ECM)
By flyinryan122
#187803 Is the MAP sensor on the throttle body? Check the connection, and make sure it is getting vaccuum
By 99cx
#187806 yeah its on. but arent those 2 plugs exactly the same?
i may have got them confused?
also can i even use the P75?
By 99cx
#187921 alright i tried to switch the plugs but it didnt have enought length to reach the other sensor so it must be right.
anyways then i bought new wires and tried again, still nothing
that ECU fault code is gone but still have 41.
not sure what is is now?
By 99cx
#187943 just checked, im getting spark fuel and air...
it must be something? anyone know? maybe the timing?
By 99cx
#187970 tried starting again and just hear a HUGE BANG under the hood!
it was like a freakin explosion, kinda.
think it was from the intake mani.
What the hell is goin on! :x :x
By egsedanguy
#187976 wow bro i think you need to goover everything. make sure everything is properly pluged in. and the sound u heard proly was just all the gas in the cylinders from tryen to crank and not fireing and finally it all poped
