- Fri Aug 05, 2011 11:14 pm
#266444
Idle isn't going to be fully stable until you get the IACV wired up properly. Also, it shouldn't run well, if at all if the MAP sensor isn't plugged in. Since it is running, the unplugged MAP sensor and IACV not wired up are probably the final problems causing the engine to run rich. Might as well change the O2 sensor just to make sure. Also, the oil and excess fuel in the exhaust could potentially foul both the O2 sensor and the catalytic converter.
As for the exhaust gap, as far as I know, the best way to close that gap is to have someone weld an extension on the mid-pipe to bring the flange up to the catalytic converter flange.
I'd recommend replacing the spark plug leads since they had oil on them. Oil has a tendency to break down the insulation on the leads which can lead to leaked voltage and weak spark.
