B16, B18, B20
By weaponr82
#65441 Two dumb questions. I have a few choices with engines. B18 GSR or LS/Vtec? I don't want anything insane so lets make handling and comfort a priority. I also drive my car every day. What would you guys choose, being more experienced with this? I'm getting a good deal on both from a friend.
Also, does the GSR take premium? I never thought about it before.
By a_CoUpE
#65444 both will take premium. and imo get the gsr more reliable.
#65469 Unless you know how to build an engince or are taking it to a reputably building and they will cover everything dont even worry about the LS/VTEC.
GSR will be just fine and plenty fast for a daily. Hell, its even what Im building over an LS/VTEC.
By weaponr82
#65482 Excellent! Thanks, sometimes I like hearing it from you guys
By BADD EGG
#65538
Greasedmonkey wrote:Unless you know how to build an engince or are taking it to a reputably building and they will cover everything dont even worry about the LS/VTEC.
Agreed Ive heard stories about peoples LS/VTEC setups failing. Mainly its due to improper installation.
By a_CoUpE
#65547
yeah same here, its has to be dun 100% right or its just gonna fail and not last.
#65564 That and the LS/VTEC done right is more expensive than a GSR swap.
By weaponr82
#65605 yea I hear ya on that. I'm a cheap bastard. I picked up about $600 worth of pieces at the junkyard yesterday (for like $70) so I'm back to being in love with my coupe.
By Yasser
#66206 i prefere too the B18.
im thinking install it in my EG saloon with D16, its my daily car too.
By id3379
#66214 gsr by far...
By Got_Purp
#68065 Easy and simple would be GSR.... LSV, you would have to get dial pins(sp). Proper head tappin for oil lines and most important getting the head shaved to seet properly on the block.... It really isn't much.... you can get the head shaved from 40-50 at a machine shop and the Eagle LSV kit will run you about 200... that includes oil lines and everything else...
By defjamon26z
#68672
Got_Purp wrote:Easy and simple would be GSR.... LSV, you would have to get dial pins(sp). Proper head tappin for oil lines and most important getting the head shaved to seet properly on the block.... It really isn't much.... you can get the head shaved from 40-50 at a machine shop and the Eagle LSV kit will run you about 200... that includes oil lines and everything else...
x2
By 1hundo
#71732 b18c1 :woot:
By Josiah
#73904 did you get a motor? how does it run?
By EG Bruce
#73975 dont think anybody else mentioned this so i will, ls/vtec is a good motor but u get poor oil circulation which means more oil changes and less motor life.
my 2 cents. ps my buddy had a ls/v and sold it to by a gsr if that helps
