B16, B18, B20
By thecrow
#60110 what would be my best bang for the buck build with a b16. most hp with a reasonable amount for a engine build.
#60117 most people will say turbo. But you can find used cams for pretty cheap and make good power from them. I prefer the allmotor build. cams, cam gears, intake, header and exhaust will get you a nice peppy motor
By thecrow
#60120 we'll ill be starting from the bare block. so should i use stock pistions etc?
By civicboy
#60433 i would say go for high comp pistons like cp or summat with eagle rods,
if i had money to build an all motor, i would go for sk2 pro 2 cams, and pro valve spring and retainer, buddyclub valves, sk2 cam gears, sk2 or itr intake mani with 66mm tb, dc sports or mugen header if i had more money then defo toda excaust manifold, and spoon or tanabe excaust, and some other parts aswell, thats the main things i would do i was to build an all motor, AMer
