B16, B18, B20
By asianrob
#51018 if i remember correctly the B20 crank is the same as the LS's 89mm correct me if i am wrong tho been awhile
you can use it like that Import TUner did a engine build like that one time and made good power
95mm crank i beleive you would have to sleeve the block
