B16, B18, B20
By KingcoupeO
#156878 ok i changed my plugs and wires.... both oem from the dealership... ok so it ran fine ...then half way to waco it started bogging down and taking forever to hit vtec range rpm's. . you could here it in the exhaust and could feel the car sputtering and jerking. i also changed the fuel filter, i did it right no leaks also form the dealer and also replaced the washers that are in there..... i did the wires one at a time matching up the lengths ... the car def sputters and sounds like it boggs down ... any suggestions ... should i try the dizzy? advance or retard it ? i thought it was bad gas but i already drained that tank and put super in from another station... injectors , fuel pump ? :? :? :? :?
By Dippin_EG
#156879 you should do a compression test and a leakdown test , it may be loosing compression. How many miles are on the car?
If thats all good i would check the timing
By KingcoupeO
#156882 thats a fresh motor less then 10k on the rebuild, the heads only got 4k on it. but im sure i could do a test
By That One Dude
#157383 Check the ignition coil and the cap & rotor. Also, if you can find one, swap out the ignition control module with one that is known to be good.
Depending on the engine, the ICM can cost upwards of $270 from a dealership, but it's $60-$70 at AutoZone.
Coil is also quite expensive at the dealer, but around $40 at AutoZone.
Im hoping you got this fixed by now, if not check those items.
By KingcoupeO
#157384 ok im guna check them ... is this a common thing to happe after replacing plugs and wires? the car ran perfectly for the wholeride then outta no where just started acting up.
By That One Dude
#157434 That all depends on how old the distributor was when you bought it. I had an O'Reilly's special in my '94 DC4, and it was shit. It was in there when I bought it though. I spent six hundred freaking dollars on a new one from Honda...so be prepared to spend some money...
