- Tue Mar 23, 2010 1:53 am
#183011
Okay since theres now a F-Series Section there will probably be more interest in these engines.
This is my attempt to gather all the information around the web and put it all into a nice, easy how to. It will be continuously updated and added to.
I have not swapped one of these myself in a civic but i plan on it.
so this itself will be intrusions for my own swap.
SO why go F-Series?
pro.s
more TQ than any B or D series
& more HP than a D or a LS swap.
less expense the a B or H swap
we probley have about a 1000 into this project so far (thats including the car)
low compression
iron sleeves
con's
not as much aftermarket support .
no info on how to do the swap.
all u can find is (it's the same as a h22 swap) witch is bullshit. but thats honda-tech for ya lol
a lil bet more weight
What is F2b? its an honda accord engine and adapting a integra or civic si transmission.. The F is the engine code for the accord year letting you know what year accord engine you can use. The 2 stand for to... ok... The B is the code for integra or civic that comes with b-series engine ex: b18b1 is from integra Ls, b18c1 integra gsr, b16a2 civic si but all b-series transmission is the same so engine code doesn't matter here except that its from a b-series.
Obviously you will need the common stuff for any swap:
tranny, with linkage and shifter (94+)
starter
H-Series mounts
injectors
ECU
Wiring harness
Axles, they say integra ones but im not sure?
Now you can use an H22 tranny which most people do, or a B16 tranny and adapter plate.
best thing you can do is buy a complete accord swap
for computer ull want to get a jumper harness and preferbly a p28,p30,p0a ecu to chip/burn for your car
if you do alot of shopping around you should be able to do it all under 500
Im still learning as i go along so any more info feel free to add
Sources: http://www.honda-tech.com
http://board.accordtuner.com
SO why go F-Series?
pro.s
low compression
iron sleeves
con's
starter
H-Series mounts
injectors
ECU
Wiring harness
