- Sun Oct 17, 2010 3:01 am
#218636
k, so some faqs..
its not hard to build a g23 if you have built a b20 vtec with no leaks!
2 oil drain ports have to be plugged or welded in to mate with the f block
f23 head gasket is used
if you didnt use arp head studs your dumb
you dont have to use k20 pistons...
(if u use oe pistons from the f, waste of time low low low compression)
i am using an f22, they are cheap and i want to sleeve one in my spare time, they are 85 at local junkyards....
f22a6 is what im using, it has an 85mm bore with a 96mm stroke!, k20a's have a 86mm bore and a 86mm stroke,
im overboring my block to 86mm anyway, and im adding forged pistons and rods for my f block from airias, they only make pistons but they sell eagle rods too.
if u use a compression calculator found by using google.com, you can figure out all the specs for everything and plug it in, im going with 11.5.1 pistons so my total compression ratio is actually 10.4:1
im opting in for a sleeve saver, i think they let u push the limits of a stock sleeve, for up to 600 whp and high boost without hurting your pocket..
i moved back home from portland, those guys are nuts, ryan at vip performance was running a sleeve saver on his sohc vtec turbo making 500whp for about 2 years, till he got greedy and blew it.. 30+ psi does that....
so, f22, arias 86mm 11.5:1 pistons made for the F! and eagle rods made for the F!, im going boost so balance in my engine is a must, plus im an engine builder so im doing it 80% right! (the other 20% is just sleeving the damn thing....)
list for my build...
f22a6 block - have
h22a head - have
b series tranny - have
hasport mounts - have
t bracket - have
k20 intake manifold
k20 to h head adapter plate (qsd)
all gaskets
acl bearings
arp head studs
arp main bolts
home made turbo kit - have
qsd h2b kit
tranny casing cover (cracked on me)
damn i cant remember anything else... lemme know if i forgot something
"smoke me a kipper ill be back before breakfast" - ace rimmer
