- Tue Nov 27, 2012 12:19 pm
#320990
There are no codes related to this issue.
And if the TPS was the issue wouldn't the idle act wonky the whole time and not for just the first 5-6 mins?
EJ1_MK wrote:Would check the TPS or throttle position sensor, if it is out the car will run horrible. and if you put a new throttle body on it came with one. There is a voltage reading that it should be in when it is closed and fully open.
Check your codes first and see what that comes up with.
They call me Mr. Brown Rice
