i let it run for awhile and poked around the engine bay jiggling wires, connectors, vaccuum lines, anything i could see to jiggle. give it a little gas and it sputters but does rev up if u give it enough gas. i looked for anything that would cause any problems but nothing i jiggled would change anything. shut it off and unplugged and replugged iacv, map, iat, and tps then started again same problem again... only this time i got a CEL!!!
so i checked the code... 1 long blink= 10-IAT sensor
http://shop.advanceautoparts.com/webapp ... fragment-1
could this be causing the car to not start when warm? i googled the poop out of it but i cant find much at all. the CEL didnt come back on after i checked the code and it hasnt come on since
im going to advance in the morning to get the sensor and see if it fixes the problem... idk what else to do
