#26854 i found a hook on once side of the motor and the other side i threaded a bolt though the chain into a hold on the block
By asianrob
#26857 i use the thing on top of the transmission and where the altanator sits there is a slot there i use.. but i seen many different ways too
By DannyCraQ
#26858 i just got a giant chain and rapped it around, it had hooks on the chains so thats a plus :thumb:
#26901 if you post up pics of the motor in the bay ill show you where to hook it
By chnzgoofball
#26955
D15kid wrote:if you post up pics of the motor in the bay ill show you where to hook it
x2 but it should be on the mount on the block and i did it on the distributor...
By DannyCraQ
#26989
well what i did, was take the one of front tranny bolt loosened it, put the chain loop on it, took the alternator out and rapped it around that bracket also
