- Thu Feb 04, 2010 10:31 pm
#173328
eg84dr wrote:d-mon wrote:just want to point out a couple of things:
p28 ecu requires a 4 wire ecu
you cannot use d16 pistons in a d15b vtec.
the p08 piston has an abnormally low compression height for d-series motors. you can use vitaras, though.
the lack of pistons available for this motor makes it a poor choice for rebuilding, other than the vitara builds.
my d15b's have the same t/b tensionor as my z6's
whats a four wire ecu?
you mean oxegen sensor?
im almost 100% sure you can use z6 pistons in this block
i will be trying this soon so ill let you know
why do u say you cant? too high or low compresion?
sorry, i meant o2 sensor. actually it's determined by the harness you use. btw, i recommend using a z6 harness.
d16 pistons on a d16 rod are too tall for a d15 block. that is why honda made a special piston just for the d15b rod/crank/block combination.
comp height for p08(d15b) piston is 27mm, p28(z6) is 30mm.
3mm doesn't seem like much, but it's catastrophic in an interference motor.
when i get time, maybe tomorrow, i will measure how low the p08 piston sits in a d15b, but i know already it is way less than 3mm.
none of my suppliers can get p08 pistons 'because they are jdm'
also, some d15b vtec solenoids do not have an oil pressure sensor.
a p28 requires one.(the green connector on the solenoid)
here is a solenoid off one of my d15b's without oil pres sw.:
you can check it here
http://www.zealautowerks.com/dseries.html
street machines > dyno queens
z6 turbo power FTW tuned on crome
