A place for all vehicles that aren't 92-95 (96-97 Del Sol) Honda Civics
By 92civic_vx
#301775 a buddy at work has a 98 accord with a F23A1, this morning he pulled into work and said battery light came on and it was hard to turn. i thought the belt broke. so we popped the hood and both belts were intact but just hanging there. i went to put it back on and the crank pulley was loose :? no recent work done to the car, we ordered a new pulley because the "teeth" on his are ground down smooth. i was wondering if the crank would have the "teeth" as well or is it smooth? his crank is smooth and i want to make sure we dont need to drop the engine and replace the crank. any idea why the bolt would back out?
By 92civic_vx
#301915 got time today to check it out and found the woodruff key slot has chip of the crank that broke off jammed in it :thumbdown: so the key cant go in and with a chip in the crank i will most likely be dropping in a jdm f23a from zerolift. should be picking it up next week along with a 3s-gte celica alltrac turbo full swap for the 88 alltrac my manager just got.
