By Pandathebear95 - Thu Aug 29, 2013 8:08 pm
#336110
For Sale:
Brand New, Never Used, Honda D16 Custom length I-Beam Rods & YCP Vitara 75.5mm Pistons with ARP Rod Bolts. Bought them for a JDM D15B turbo build, but moved on to another project and have no use for them. These rods are made longer than standard D16 Rods, to be used in conjunction with these Vitara Pistons, to increase compression slightly and compensate for the shorter piston size. Made for turbo applications to handle much more power than the stock rods. Rated at 500+ HP. Pistons are .5mm over stock so you will have to have your block bored out to fit. Pistons are teflon coated on the skirts to reduce friction fatigue. Sale includes: (4) 138.63mm D16 I-Beam Rods, (4) YCP 75.5mm Teflon Coated Vitara Pistons, (4) 9310 Case Hardend Full Floating Wrist Pins, (8) ARP2000 3/8" Rod Bolts, Wrist Pin Locks, & .5mm Oversized NPR Premium Piston Rings to match the pistons. You can't get this set for less than $400 brand new. Can only be used with the Honda JDM D15B and D16 engines.
Asking $350 Firm.
Link to PICS.
http://s1017.photobucket.com/user/aabikzer/library/
Asking $350 Firm.
Link to PICS.
