- Sun Jun 24, 2012 12:11 am
#309183
"""""""the part list for my car was basicly complete drivetrain from a 99-00 crv.
- gearbox + brackets + cables
- starter ( you will need to grind off the starter or the block to make it fitt in - i reconmend you mock up the box and motor before you put it in and you will see right away what i mean )
- driveshaft
- rear differential
- axles ( i used two right ones in my setup, reason- the rear diff in the crv is not in the middle, so the axles are differant length, but i put it in the middle in the civic an could use them with no mods at all, no need tho shorten or lengthen them )
- trailing arms
- lower control arms
also used
- integra rear shocks
- e-brake cables from any civic with drum brakes
- civic shuttle gas tank ( i strongly reconmend a fuelsell for this - i regret not have)
think thats it.
to go for front five lug ,the ITR front is the easyest way to go, do not waste time on the crv ones . """""""
got bored..
so i started on my awd setup for an ek iwe got ..
got a complete drive train from a crv , 5 speed manual box, rear diff e.c.t
started on the control arms yesterday .
stripped..
cut to peaces ..
trying to figure out how in the hell ....
made a " center piece thingy"... and weld..
one down and primed.
i dont have a pic of the car as is.
back to work
- driveshaft
- rear differential
- trailing arms
also used
think thats it.
got bored..
stripped..
cut to peaces ..
back to work
