By GoRide
#80125 RIP Spike.....
Man what kinda Break lines did u use?
By lopez286
#80140 men u guys dont play at all good work.
By ee8
#81761
Graham wrote:Uh oh, you are my heeeero
i'm just the postwhore.....
credits go to Bas for funding this project since it is his car, and to Randall for building it..... :D
By ee8
#86872 Started today on the suspension, trial fitting etc. We intend to completely build this car with every component, then dismantle it and bring it to the painters and then re-assemble it again.. saves us the trouble of finding out things may not fit or need modification after it's been painted... this is a little more work, but it'll be worth it in the end..
Mounted the function7 rear lower control arms with the ASR brace in black. The main trailing arm was coated and mounted a prothane urethane main bushing. I prefer the prothanes over the energy suspensions due to the fact they have a steel casing which you press in like the oem ones
Then mounted the Ingalls camber correction arms in the back and the Suspension techniques anti swaybar onto the ASR brace. One thing I noted last time I installed this combination is that the ASR brace moves the ST mounting brackets back about 1 inch. In the way the ST is mounted, this gives a slightly less beneficial position for the space between the swaybar and the shocks. it leaves about 3/4 inch of space, this is in the position when the car is raised off the ground and when on it's wheels, the space is more, so no real worries here, but just something to notice.
In the front, mounted SRR camber correction arms and powdercoated the front uprights. Installed new bearings and ball joints and installed ARP extended studs. Also used cv joints to keep the bearing races together when car is rolled around...keeps it all in one piece.
Need to coat the front subframe, front lower arms and rear toe-ins and put urethane in and then the suspension is as good as checked ok fitmentwise.
pics:
#86883 Isn't it an idea to spray the shell before putting new bits on?
By hontec
#86915
SlipCivic wrote:Isn't it an idea to spray the shell before putting new bits on?
ee8 wrote:Started today on the suspension, trial fitting etc. We intend to completely build this car with every component, then dismantle it and bring it to the painters and then re-assemble it again.. saves us the trouble of finding out things may not fit or need modification after it's been painted... this is a little more work, but it'll be worth it in the end..
#86916 You see... I love pictures! :jerkbow:
By hontec
#86921
SlipCivic wrote:You see... I love pictures! :jerkbow:
LOL! :lol:
By smokinsoljah420
#86923 wow i cant wait to see finished!! :thumb: expect nothing but the best from my Dutch brothas :thumb:
By ee8
#86941
Civic_HatchSI wrote:wow everything is always so clean! keep up the good work Niels :D
haha, i didnt do anything today lol....
hontec/randall did all the work.
