By ee8
#81558
Well guys, winter has started and that means no mowing laws, trimming hedges etc etc. That means my ass is bored and aching for a new challenge. HONTEC has been building more and more odd projects lately and it's becoming more of a challenge to be creative. I think I've hit the sweetspot with this one, always was a fantasy to build a rwd honda with the engine longitudonally placed like the JGTC cars. Decided to go nuts and just do it..Bought a Porsche G50 5-speed transaxle which will be mounted with an adapter inverted to an NSX C30A 3,0L V6 DOHC Vtec. All this will be placed in the rear of an Integra Type R RHD Chassis. Next to the Civic EK we're building right now for full circuit use with a K20 with sadev 6-speed sequential transmission/drysump this will be my winter project.
The Porsche G50:
Furthermore I laid my hands on 8 ex BTCC Accord centerlock wheels 8x19 ET+55
Brakes will be AP discs 380x32 mm with Wilwood 6 Pot calipers on all 4 corners( Yes! I have a Brake Fetish!!):
The RWD base will start with 92-95 Civic AWD rear trailing arms which were built for the Japanese and Austrian markets:
Bored today: 16x7 ET+50 oem jdm Itr wielen:
8x19 ET+55 BTCC Accord:
Update 04-11-2008
Well read 243435336373 workshop manuals and walked around with my dial caliper for 23 days and found out there is not too much difference in the trailing arms for a 97-02 crv and 92-95 AWD civic. The AWD trailing arm has a one piece bearing retainer but unfortunately for a bearing diameter that does not suit my requirements (too small a diameter) However the crv bearing has the same bore as the front ITR bearings!! The only difference is that the awd setup has a bearing flange and the crv has a separate bearing...even better!!! lathed down the awd bearin house and mounted the crv bearing to the awd counterflange!!! eureka!! and the standard ITR hub fits like a glove with now the ability to fit a standard ITR front CV joint!! This is what I was looking for...compatibility,..The ITR hub needs some modification because the bearing for the crv is 4mm thicker than the ITR bearing, but that's easily fixed..
Pics:
oem 92 civic awd inner brace with bearing retainer:
CRV complete bearing and flange as one unit:
ITR 27mm drive spline and hub that will actually fit the crv bearing:
Total setup:
By ee8
#81559
Update 22-11-2008
Tha bitch has arrived:
Update 23-11-2008
Glass out, all rusted parts will be replaced with oem parts, except the roof which will be a custom molded autoclaved dry carbon unit:
update 25-11-2008
Scrap:
Nose Job:
By ee8
#81560
update 29-11-2008
Looking good: temporary setup using a Legend C35A5 for dimension and axle line-up...
extremely low center of gravity....and no major issues with axle line-up...Me=Happy!!:
By smokinsoljah420
#81561 :o ::faints:: wow you guys are the shiznit!!!
#81573 So... ummm.... when that's done can you send it to me :thumb:
By Faded_Milano
#81577 That's it! I'm learning Dutch and coming to work for you!
By Classiccarsrule85
#81579
Gorveatt wrote:So... ummm.... when that's done can you send it to me :thumb:
lol that would be awsome when it is done exspecially at those car shows if they cover up the motor in the back opend the hood and wheres the motor......or at the strip you hear the motor but dont see it until it passes you
Here is a question though how are you gonna even out the chasis now that all the weights in the back and you have a higher output motor wont it be a little hard to steer.....i think it would understeer? since alot fo the weight is off the front wheels....im guessing gas tank to be moved to the front .....
By ee8
#81582
seeing a dc2 making burnouts and donuts would even more fun lol....
gastank and drysump canister will be in the front, even as battery etc. we are on an experimental base, so do have to figure out some things.....
By zeppelin101
#81584
Classiccarsrule85 wrote:i think it would understeer? since alot fo the weight is off the front wheels....im guessing gas tank to be moved to the front .....
Turn in would suck but after that it would epic tail happy fun :P
As long as you know the corner weights you can shift stuff around as you like, but as you said, tank and sump etc up front will help a lot
Probably better mounting it longitudinally as well as you put most of the weight dead centre rather than near the back I guess...
By asianrob
#81677 damn you mother fu%ker$ can do anything!!! :lol:
By marvinp8700
#81749 whats the price tag on something like that?
Graham wrote:4wd eg wtf!!!!!!! :o
you didn't know they were made factory? They were only available in as sedans though
By ee8
#81760
true.
only thing is the rear trailer arm is about 40mm longer then the hatches and coupes.....
By asianrob
#81767
they also made 4wd tegs too
